DirtyImpreza.com - The Off-Road Impreza Community DirtyImpreza.com - Homepage DirtyImpreza.com - Forums DirtyImpreza.com - Store DirtyImpreza.com - Classifieds
Go Back   DirtyImpreza Forums > Video & Picture Forums > Member Journals
Reply
Thread Tools
Old 11-07-2007, 08:14 PM   #31
E_Swift
Registered Member
Default
You probably can't be totally sure on #1 or #2 until it is disassembled. Just take many pictures, number all the parts by location with a paint pen, etc first. Then tear into it.
Once disassembled, we can look a bit more into what exactly happened. So what was the history of the failure, from first indication to ...? I saw something about a bent rod...? Some evidence was lost when the timing belt was removed.
E_Swift is offline   Reply With Quote
Old 11-07-2007, 08:19 PM   #32
I Like It Sideways
Forum Moderator
I Like It Sideways's Avatar
Send a message via AIM to I Like It Sideways
Default
interesting about #1.
I should have disassembled the head myself. I left it with the dealership, stupid me. From what I saw, it seemed like the valves were in good shape.
I'm picking it up tomorrow and I'll be looking for the operations manager that made the decision.
I'll look into sending it off to the lab. That would more than likely be worth it in this case.
And the spark plug is intact.
Thanks for the feedback on the pictures. I could use all the help I can get with this.
Edit:
There were no signs of failure, until the engine wouldn't turn over upon trying to start it. Before that, it ran perfect, and I didn't hear any suspicious sounds. Although my girlfriend said that she thought my car sounded different than it did before I took it in to get serviced. My only guess is that she may have been hearing this object bouncing off the valves in the intake runners.
The dealership listened to my car once I was able to get it turned over and started, and said that they thought it may have been rod knock.
What would have been lost when we removed the timing belt?
__________________
2006/2008 - Western Ohio Region SCCA M4 Champion
2007 - Ohio Valley Region M4 SCCA Champion, 2nd in M4 Western Ohio Region
2008 - Great Lakes Division M4 Champion
2009 - ESC 3rd place M4
Matthew Noble Marker= - You will not be forgotten. Rally on.
I Like It Sideways is offline   Reply With Quote
Old 11-08-2007, 09:03 AM   #33
E_Swift
Registered Member
Default
The name of the place is Chicago Spectro Service Laboratory, Inc
773-229-0099
So how did you get from not being able to turn over the engine (assuming here you were just using the electric starter, right?) to running?
Potential mis-timing proof would be lost when the belt was removed.
There are only a few things that will prevent an engine from being turned over. One is valve-to-piston interference (unlikely but always a question after doing a head gasket)
How soon after the service did you see problems? This you would know right away.
Have you looked at measured/plastigaged the bearings? This is how you can rule out rod knock as a contributor.
Old 11-08-2007, 09:16 AM   #34
I Like It Sideways
Forum Moderator
Default
At first I thought it was a dead battery. So I replaced the battery with a stronger one while I was at it. That got the engine to turn over and fire up. I thought the belt may have jumped a tooth, but the dealership said it did not (who knows if they are yanking my chain). That was one of the first culprits I asked them to look for.
I put 794 miles on the car before this happened.
I did not know I could plastigage the bearings. We haven't torn down the block enough to get to them.
I always thought that rod knock was a gradual onset, not sudden though.
__________________
Old 11-08-2007, 09:39 AM   #35
E_Swift
Registered Member
Default
Well, you're right - rod knock is usually gradual onset.
This is a "traditional" ignorant/incompetent mechanic issue in some cases when the head is removed. Basically, if both heads aren't drained of coolant completely before loosening the head bolts, you stand a strong chance of getting coolant in the crankcase. You see this more on V engines and inlines rather than boxers, but I'm sure it is possible. Usually, an oil change cleans things out, but it really should be 2. Did the dealer charge for an oil change? An oil analysis could have been done, but since you have also pulled the heads, it becomes impossible to prove.
In any case, the bearings will have a characteristic coloration if they have been attacked by acid, which is what happens to coolant that has mixed with the oil, in addition to boiling where pressure and heat transfer are needed, and generally decreasing viscosity and oil pressure.
I'm still betting on foreign debris, given the size of that lump.
Old 11-27-2007, 12:22 AM   #36
I Like It Sideways
Forum Moderator
Default
It was definitely caused by the foreign object... but they just won't own up to it. I think I am going to send it to that lab... maybe we can figure out what exactly it is, and use that as evidence.
After all this is over, I'll disassemble the block and rebuild it.
As for an update on the car:
Stripped out the carpet and center console. Trunk has been stripped as well. Need to remove sound deadening though.
And installed this graphite gasket from GrimmSpeed. I would definitely recommend it to anyone, this gasket rocks
Fixing this leak caused another to surface... so I'll be ordering another gasket.
Hit 100k on the body last weekend
__________________
Old 11-27-2007, 03:49 PM   #37
strat
Senior Dirty Member
strat's Avatar
Send a message via AIM to strat
Default
love the video of the stpr chicane. i'm less than an hour away from wellsboro and i love to romp up there. i'll have to find some of the footage from the subaru meet we had up there last year...
you coming to stpr in 08?
strat is offline   Reply With Quote
Old 11-27-2007, 04:30 PM   #38
409industries
DIRTFTMFW
409industries's Avatar
Send a message via AIM to 409industries
Default
Quote:
Originally Posted by I Like It Sideways View Post
WTF you have almost the exact same angle in the above shot as the one i took of my car! Same stupid tilt and everything.
I love the picture of 100K on the odometer... all artsy!
409industries is offline   Reply With Quote
Old 11-27-2007, 05:45 PM   #39
I Like It Sideways
Forum Moderator
Default
You bet I am!! That was taken in '06. I will hopefully be crewing, a friend and I only spectated in 2006, and I love crewing more than spectating.
I definitely would love to see the footage from your meet. if it was posted on RS25, I may have seen it
Thats hilarious! What is it with the tilt? I saw your picture before I took my interior out... thats what motivated me to get to it and take out the carpet. I still need to remove the sound deadening, among other things.
Its going to be super easy to tighten the hand brake now
I go overboard with pictures sometimes. The 100k shot was another point and hope it takes a cool shot haha.
__________________
Old 11-27-2007, 06:06 PM   #40
strat
Senior Dirty Member
strat's Avatar
Default
i don't believe it was posted on rs25... it was a variety of subarus (legacy's and imprezas... sedans and wagons) the one vid my buddy made got taken down on streetfire.
i'll be there in 08 as well. probably just spectating. any plans to run the charity time/distance rally they have on friday before stpr?
Old 11-27-2007, 06:18 PM   #41
kreitz3
Senior Dirty Member
kreitz3's Avatar
2002 WRX
Send a message via AIM to kreitz3 Send a message via MSN to kreitz3 Send a message via Yahoo to kreitz3
Default
I too will be there in '08.
I still can't wait to see the GC this weekend!!!
__________________
2002 Aspen White WRX - gone
1996 Outback Sport - 250,000 miles
Never argue with stupid people. They will bring you down to their level and then beat you with experience.
kreitz3 is offline   Reply With Quote
Old 11-27-2007, 07:04 PM   #42
E_Swift
Registered Member
Default
So I take it that this is now a full-on rally project?
What's this weekend- thought rallyx was over for the year....?
Old 11-28-2007, 01:23 PM   #43
I Like It Sideways
Forum Moderator
Default
A few Subaru guys here at Purdue are coming over to my house for food, forza, DiRT, and driving. Kyle is just the outsider from Ohio, that we consider as one of our own hahaha
You're welcome to come too, if you can make the time! I think we are doing it tomorrow night/Friday
And this is now a rally project. It will be well over another year before it's finished, but gotta start somewhere.
__________________
Old 11-28-2007, 03:31 PM   #44
kreitz3
Senior Dirty Member
kreitz3's Avatar
2002 WRX
Default
Hey. I'm not the outsider. You are the Buckeye posing as a Hoosier. Mole.
__________________
Old 11-28-2007, 03:34 PM   #45
409industries
DIRTFTMFW
Default
I wanna come play too :(
Nice to see its a full on rally project now! DI has quite a few GC builds in the works.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
