Go Back   DirtyImpreza Forums > Video & Picture Forums > Pictures Forum
Old 06-26-2012, 12:20 PM   #1801
Bubba02sti
Colorado Mob Boss
Bubba02sti's Avatar
Send a message via MSN to Bubba02sti
Hydrolocked?
Originally Posted by coldturbo
"The AP is like a suit from Sears off the rack. It will fit, it will look good and will be appropriate. A OS tune is suit from Italy made by Armani. The Armani will be made to YOU, out the finest cloth and will make bitches fall in your arms. Do you want a Sears suit?"
Bubba02sti is offline   Reply With Quote
Old 06-26-2012, 12:32 PM   #1802
89ChevondaSI
89ChevondaSI's Avatar
hopefully not. I did have stuff in the intake but not enough to kill it. I currently am not getting a signal for spark to the ignition coil. cause it just slowly died on me. so now I am gunna try an ignition module first.
and It cost $158 for a replacement phone... my feet splooshed in water so I looked down and there was my phone in the car under water. :( so now im gunna gut the interior and rip all the carpet out. and install drain plugs....
I was born 2 be off-road
Pavement is fun but less of the world is paved.
89ChevondaSI is offline   Reply With Quote
Old 06-26-2012, 05:51 PM   #1803
wagonryan
wagonryan's Avatar
"you can't find the limits if you don't exceed them"
went into a puddle too slow with too many people in car.
car got high centered, "skid plate" bent so bad it was dragging when i got towed out
car started right up, still want a snorkel though
yeah I need to get a dual range and more higher
fun nonetheless!!
Lift it: build it, break it, fix it. Repeat.
wagonryan is offline   Reply With Quote
Old 06-26-2012, 05:52 PM   #1804
wagonryan
wagonryan's Avatar
oops double post
Old 06-26-2012, 08:00 PM   #1805
slowbaru
The Slowest
slowbaru's Avatar
87 bmw 325is
slowbaru is offline   Reply With Quote
Old 06-26-2012, 08:04 PM   #1806
Skemcin
Skemcin's Avatar
Originally Posted by slowbaru View Post
A car with no wheels and tires looks like someone with their teeth knocked out. Hope its back on the road soon ...
Offering the strongest, most intelligent off-roading products for
your everyday enjoyment.
Portions of all proceeds are donated to worldvision.org and gorillafund.org.
Visit gorillaoffroadcompany.com and follow @gorillaoffroad now!
Skemcin is offline   Reply With Quote
Old 06-26-2012, 08:21 PM   #1807
slowbaru
The Slowest
slowbaru's Avatar
87 bmw 325is
I'm putting it back to stock. Its been like this since Oct
Old 06-27-2012, 03:28 PM   #1808
89ChevondaSI
fun nonetheless!!
lucky.... I might need an ECU. I pulled mine out and the bottom 3 inches of it was filled with mud....
Old 06-27-2012, 03:49 PM   #1809
89ChevondaSI
where my ECU was sitting...
Old 06-28-2012, 06:25 PM   #1810
89ChevondaSI
LIFE! cleaned the ECU out. let it sit for 2 days then vwala! it started! now I just need a coil to fix the run rough. no/ intermitent spark on one side of the coil. good/ strong signal.
Old 06-28-2012, 06:43 PM   #1811
89ChevondaSI
Before:
After:
The inside of my ECU:
and yes. I tried getting my car running with the ECU like this. 3 days later I took everything apart. Took the ECU apart and cleaned it with water...yes water. then let everything sit/dry for 2 days. Then I plugged it in and BAM! It runs! now I just need a coil to fix the run rough. Subie for the WIN!!!!
Old 06-28-2012, 08:12 PM   #1812
wagonryan
wagonryan's Avatar
Right on dude !!!!! are you going to relocate it higher up? what other electrical stuff would be a good idea to reroute higher? I have wires running right by my front wheels I wanna redo to protect em.
and to stay on topic
Old 06-28-2012, 09:33 PM   #1813
Skemcin
Skemcin's Avatar
If the coil is the same as an 02 OBS - I have one ...
Old 06-29-2012, 07:09 AM   #1814
ajchxc
2012 DGM WRX Hatch
got her a bit muddier this week. I found a fantastic new development that doesn't have pavement or anything, just a bit of plumbing here or there and is hidden between more new developments they are currently working on and some old farmers fields. I spend 45 minutes without seeing anyone while I was there!
ajchxc is offline   Reply With Quote
The Following User Says Thank You to ajchxc For This Useful Post:
Old 06-30-2012, 04:52 PM   #1815
89ChevondaSI
Tried a coil. didn't fix it. so now i'm gunna go to the junk yard monday for parts...
