Go Back   DirtyImpreza Forums > DirtyImpreza Technical > Other Subaru Model Technical > Forester Technical
Old 09-09-2010, 02:57 PM   #1
slushpuppy
Default 2001 Forester S Hubs
First post and new to Subaru, LOTS os questions! So many questions so i will start by saying GREAT SITE!!! LOVE MY Subaru!!!
First; do i have to pull the axel shaft to change the bearings in the rear?
Next; what is the best hub puller for both front and rear?
Next but not last will ask more later; is a 12 ton press enough to remove and install the bushings in the rear links?
I have to replace the struts and springs so was thinking might as well go all out and do the front and rear complete. This forester runs really good with 91K miles everything works as it should few small dents no rust other than rusty bolts. Please help if you can.
slushpuppy is offline   Reply With Quote
Old 10-21-2011, 08:36 AM   #2
bluesguyej25
2008 Impreza n/a
Send a message via Yahoo to bluesguyej25
http://www.alldatadiy.com/alldata/AF...4680/136264684
R.I.P 01 FOZZ
hELLO 08 IMPREZA
I dont always drive on dirt,
but when I do, i prefer Imprezas
..stay dirty my friends..
bluesguyej25 is offline   Reply With Quote
Old 01-12-2012, 07:45 AM   #3
Gr3en
Gr3en's Avatar
05 RS 99 Foz
Send a message via AIM to Gr3en
I have personally done both front and rear bearings and the fronts are by far the easiest. The long bolt that holds it all together is seized. The bushings from the lateral links are seized to the bolt. You are better off getting good used rear knuckles and new bushings for the outside of the lateral links or do a rear disc conversion if you don't have the, already. Pay a shop to do it. Save yourself some back pain and grey hair.
Offering the strongest, most intelligent off-roading products for
your everyday enjoyment.
Visit gorillaoffroadcompany.com and follow @gorillaoffroad now!
Portions of all proceeds are donated to worldvision.org and gorillafund.org.
Gr3en is offline   Reply With Quote
Old 05-23-2012, 08:09 PM   #4
DirtySF5
DirtySF5's Avatar
silver 2001 Forster
Thanks for posting this !
DirtySF5 is offline   Reply With Quote
