Go Back   DirtyImpreza Forums > DirtyImpreza Technical > GE/GH Chassis Impreza (Model years: 2008+) > Electrical and Lighting
Old 12-15-2010, 04:45 PM   #1
08OBS
08OBS's Avatar
Default Rally Innovations and DIY Light bar
I ordered a Rally Innovations light bar this week with 2 Hella 700's, 500's and 500 fogs. I am also making a light bar myself. After seeing the ones on here it seems fairly easy. I will have pictures soon.
08OBS is offline   Reply With Quote
Old 12-18-2010, 10:04 AM   #2
Mustang50turbo88
Mustang50turbo88's Avatar
Dark Grey 2008 2.5i
Sounds good! Can't wait to see. The one I made rusted, even with the 900 coats of paint lol. I was looking at the rally innovations as a replacement, but I wasn't sure how it would work with the 700's. So if I'm reading that right, you are putting 6 lights on it? That's awesome!
Dirty 08 Sedan
Mustang50turbo88 is offline   Reply With Quote
Old 12-18-2010, 01:45 PM   #3
08OBS
08OBS's Avatar
I know I can fit 4 lights so I think 2 more will fit fine, if not I will put on a light bar that I made. I talked to the guys at RI and they said 700's would fit fine on top. I can't wait to get it.
Old 12-20-2010, 04:41 PM   #4
08OBS
08OBS's Avatar
Some lights came in. Hella 500 Fogs
[IMG]
Old 12-21-2010, 03:25 PM   #5
08OBS
08OBS's Avatar
I drew this up. Easier to read than the Hella instructions. Can anyone answer my question?
Old 12-24-2010, 04:16 PM   #6
08OBS
08OBS's Avatar
I wired my fogs just like in the diagram, but they seem to not be working? Any idea on what I did wrong?
Old 12-25-2010, 11:27 AM   #7
08OBS
08OBS's Avatar
Got my 700ff and 500ff today. Now I just need the light bar which is coming on the 30th! It's gonna look great and work awesome.
Old 12-25-2010, 01:43 PM   #8
SnakeFart
Premium Supporter
SnakeFart's Avatar
That wire doesnt need to be connected to ground. Chassis ground is chassis ground. Some might not work as well as others but its going to complete the circuit.
I did mine like that but make sure that fuse to the switch with the LED isnt blown. I broke mine 2 times because it was only a 2.5 amp fuse. (thin element) I upped to a 5 amp. Which isnt going to fry anything if it shorts to ground. Its going to pop just as fast. You can tell if the fuse is blown or not just by seeing if the light comes on.
If it isnt working make sure the relay is click when you activate the coil. Simply touch the 85 side wire to chassis and it should move in your hand or you should hear a click. if that is ok, check the ground at the lights. Usually its a ground problem.
Think. Feel. SnakeFart.
SnakeFart is offline   Reply With Quote
Old 12-29-2010, 05:32 PM   #9
08OBS
08OBS's Avatar
I got my light bar today and it was an okay install, I had to remove some shield by the exhaust to get the bolts in, and had to cut some of the splash guard. Other than that it was easy. The bar looks great and feels stable. The lights are not wired yet doing that tomorrow.
Old 12-29-2010, 05:57 PM   #10
SnakeFart
Premium Supporter
SnakeFart's Avatar
Sexiness for sure. I would have made a top mount too but then it would have blocked my WRX plate delete and my super-tones.
I dig it.
Old 12-30-2010, 12:01 AM   #11
Gnome
Gnome's Avatar
this ground does seem redundant...
What sucks and blows and doesn't complain about it? My turbo
2003 WRX
Re: sig pic
you have nothing big to be jealous about... :wink:
Quote: Originally Posted by Gnome
relax i understand your just jelous of my size
Quote: Originally Posted by Bubba02sti
I was just giving you crap again... the size is fine now...
grrr you and you size issues, are you jelous mines bigger than yours?
im just giving you can crap... can you make the pic any smaller... i think its too large still...
[02-09, 12:39] RS MN vtec just kicked in, yo.
RSmn-gay checks(
XVI)
Gnome is offline   Reply With Quote
Old 12-30-2010, 10:24 PM   #12
409industries
DIRTFTMFW
409industries's Avatar
Send a message via AIM to 409industries
You definitely don't need to worry about the ground coming of the neg terminal on the battery, this is already grounded with the factory wiring.
The diagram you drew looks correct. Take a testing light or multimeter to the power wire that goes to the lights and and make sure the relay is sending power to that wire when the toggle is in the on position. If its not, start tracing backwards through your "hot" connections and see where the juice is getting stopped!
409industries is offline   Reply With Quote
Old 12-31-2010, 04:04 PM   #13
08OBS
08OBS's Avatar
I got the 700's wired. I need to do the 500's now. It is freezing in my garage. Can't wait to get them done.
Subaru FTW
2005 WRX
Old 12-31-2010, 05:28 PM   #14
08OBS
08OBS's Avatar
Subaru FTW
2005 WRX
Old 12-31-2010, 06:10 PM   #15
dirtslayer
dirtslayer's Avatar
i dunno if im feelin the angle of the bottom lights man.. not hatin, jusss sayin
dirtslayer is offline   Reply With Quote
Tags
bar, hella, innovations, light, rally
