Go Back   DirtyImpreza Forums > DirtyImpreza Technical > GD/GG Chassis Impreza (Model years: 2002-2007)
Old 12-02-2011, 10:38 AM   #1
Cambo
Cambo's Avatar
Default Cold Weather Fuel Seep
In cold weather, certain 02/03 WRXs may have fuel line seep. Only app 5724 cars are affected by this in 16 cold weather states - Ak, Co, Io, Id, Me, Mi, Mn, Mt, Ne, ND, SD NH, NY, Vt, Wi, Wy. There will be a warranty extension for this particular issue for the remaining 34 states. #WVK-21
i live in southern Cali and i own a 02 WRX (stage 2). apparently this "recall" doesnt cover California. last weekend i made a trip up to our local mountain (Big Bear) to do a little snowboarding and when i came out after warming my car up, i smelled fuel really bad.
i was wondering if anyone here has had this issue and fixed it. i would like to fix this issue as i have a 2 year old son and i dont want my car to blow up
Thanks
Cambo & TheDub
RallyX Car- WRB '06 WRX Sedan (TheDub) ^^^
DD- Silver '02 WRX Wagon (Beca "TheWagon")
Cambo is offline   Reply With Quote
Old 12-02-2011, 11:01 AM   #2
wolfman79
wolfman79's Avatar
The lines and clamps at the fuel rails are usually the source of the problem. The fix is pulling the intake and replacing all the soft lines. It affects more than just bugeyes, we usually start with simply tightening all the clamps we can without pulling the manifold. If that doesn't take care of it then we do the whole nine.
RIP NJM 02-05-83 08-23-08
wolfman79 is offline   Reply With Quote
Old 12-02-2011, 11:36 AM   #3
alosix
WR Blue 2002 WRX
FWIW.. The fix they do in the recall really isn't worth a @#$!@# anyway.
After attempting to let them fix it. I bought some goodyear line and tightened everything up real good. That worked for about 3 years in a fairly chilly climate.
If I were working with the stock stuff again I'd probably put some red/blue locktite on the threads of the clamps to hopefully stop them from moving around.
another option might be to use the crimp style clamps that most of the aftermarket ones use.
alosix is offline   Reply With Quote
Old 12-02-2011, 11:59 AM   #4
MConte05
MConte05's Avatar
Send a message via AIM to MConte05
Idk, when I had mine fixed they replaced the entire fuel lines underneath the intake manifold.
MConte05 is offline   Reply With Quote
Old 12-02-2011, 12:27 PM   #5
alosix
WR Blue 2002 WRX
Yeah.. the factory 'fix' is another set of hard and soft lines. Hard a hair shorter, soft a hair longer.
Still used the same style clamp, still worked loose over time.
FWIW, the dealership that did it didn't seem to have the brightest techs on hand. A good number of my heat shield bolts were broken/stripped from them doing the clutch stutter fix.
Old 12-13-2011, 07:40 PM   #6
Evil_XT
DoubleGray 07 OBS SE
That tsb is miserable, especially when you are trying to make a living and make the customer happy at the same time..That cold weather bs about the northern states only is such a load of...... i can see this happening to alot of vehicles. What if you have a car shipped from ca to nj and it happens?...your screwed...stupid..
Evil_XT is offline   Reply With Quote
Old 12-14-2011, 10:49 AM   #7
Cambo
Cambo's Avatar
i found the warranty extension with the dealership and they're gonna cover it
Cambo & TheDub
Old 12-14-2011, 05:46 PM   #8
bone_1113
SoundEffexSutter
bone_1113's Avatar
wow im glad i seen this, i have a 04 and when it started getting really cold here i started smelling fuel as well...better check all my lines!
~Anthony Sutter~ AKA BONE!
wifey- "Babe you would be so proud! I just ripped up a mud puddle and the turned around and did it again!" -awesome
bone_1113 is offline   Reply With Quote
Old 12-14-2011, 05:57 PM   #9
geekmonster
Ultimate DI Postwhore
geekmonster's Avatar
Dented 02 WRX Wagon
Send a message via Yahoo to geekmonster
cam, kinda had the same thing happen this morning. had a faint fuel smell when i opened the door after parking at work. its been getting pretty chilly down here and had heard something about this a while ago, but forgot about it. i'm debating on what to do.
geekmonster is offline   Reply With Quote
Old 12-14-2011, 05:59 PM   #10
Cambo
Cambo's Avatar
the extended warranty expires in 2013 for the effected cars so if you wanna get it done, do it now
Cambo & TheDub
Old 12-14-2011, 09:06 PM   #11
alosix
WR Blue 2002 WRX
x2. I'm not sure what the 'book' charge is but i'm guessing its a 6-8hr ish job. Its not complicated, but its such a pain to get the intake off. If you don't plan on swapping something else in yourself I'd make sure to take them up on it. Can't say I'd expect it to be a perm fix though.
Myself.. I really like having the fuel lines accessible without taking like 1/2 the top of the car apart
