Go Back   DirtyImpreza Forums > DirtyImpreza Technical > GD/GG Chassis Impreza (Model years: 2002-2007)
Old 01-06-2012, 09:27 AM   #1
Scrambles
Scrambles's Avatar
2002TS BRP
Default Adding cruise control to a TS
I'm wondering if anybody has ever pulled this off?
I have a bare-bones 2002 TS with no cruise - I'd love to install some type of cruse control, factory, aftermarket - I don't care. I've done some searching, and I can't find a thread anywhere where someone has actually retro-fitted any type of cruise control into a bugeye that came without it.
I spend a lot of time on the interstate, and I'm starting to think a brick is my best option....
Thanks!
Scrambles is offline   Reply With Quote
Old 02-04-2012, 12:11 PM   #2
mannac
mannac's Avatar
'02 T-WRX, '72 240Z
There shouldn't be any retrofitting involved. I imagine you would just need to get the parts and add a couple pins to the ecu plugs. Or there may already be a plug there for it, I don't remember. My TS doesn't have cruise either.
  • '02 WRX swapped TS - 240k+ and still kickin'
  • '72 Datsun 240Z in pieces
mannac is offline   Reply With Quote
Old 04-20-2012, 08:26 AM   #3
LPXLTT
2007 OBS
Send a message via AIM to LPXLTT
TS was what the brighton was to the legacy.
I have never tried this but in theory its just bolt on. When I was helping my friend swap a TS engine to his RS (both 03) the ECU looked to be the same. If its disabled due to software I do not know though.
LPXLTT is offline   Reply With Quote
Old 08-12-2012, 10:22 PM   #4
K-limt
Blue, 2002, 2.5TS
working on it slowly. its just a bolt in cruise control actuator and mounting bracket under the hood, a electronic cruise module under the dash, and the selector knob on the steering wheel. iirc the wiring harness is already set up for the selector knob to under the dash. i just popped off the cover and air bag to take a look...i'm waiting for another car to show up at pick n pull before i can get the parts to continue. I definitely have to run the wiring from the control module to the actuator though.
wiring diagrams are here.
http://ken-gilbert.com/impreza-manuals
K-limt is offline   Reply With Quote
