| Register | vBPicGallery | Invite Your Friends | FAQ | Donate | Members List | Social Groups | Calendar | Mark Forums Read |
Thread Tools |
#1 |
Car: 91SS,06WRX,01RS
11/27/2007 - Stripped Interior, Grimmspeed exhaust gasket install
3/6/2008 - DI and Redline Vinyl applied 3/10/2008 - STi drivers seat installed 3/26/2008 - Refinishing the stock 6 spokes 4/8/2008 - 2 Hella 500 driving lights installed 4/9/2008 - 4/17/2008 - Motor pull, head gasket work1, Machined Heads and Completion 7/10/2008 - Front axle replaced 12/3/2008 - It's Team Dynamics Time 3/8/2010 - Seam welding, burning lots of oil What started out as the need for a daily driver quickly turned into a desire. I am still in the early stages of this desire, but the ball is rolling, and its not going to stop until I get there. I received this 2004 WRB STi as a present... and I couldnt be happier with it. I never thought I'd be so lucky to own an STi... but here it is Well...all joking aside, I am the proud owner of a 2001 2.5RS. Have been ever since I drove it off the lot. I didnt start out with plans for the car... All I knew is that I liked how it looked and handled. I didn't even fully appreciate how lucky I was to pick it up with low mileage (51k), and for a decent price ($9500). It wasn't until I started driving the car, posting up online (did I ever sound like a newb... I hate reading my old posts), and talking to other Subaru owners, that I realized how lucky I am to own this car. This is how it looked when I took it off the lot.. never since then has it been so clean. ![]() Back up a bit. My first car was a 1997 Saab 900 SE Turbo ![]() Ignore the windshield wipers... So stepping into the RS was a step down in torque and horsepower. The Saab was rated at 195 ft-lb of torque, at ~8psi. I was boosting ~15psi, with a catback exhaust, so I'd guess the torque was closer to 205-210. So given that, it wasn't long before I decided the RS needed something more. So I quickly found that Cobb is a name commonly used when talking about Subaru's. I opted for Stage 2 for the RS, which includes
![]() ![]() ![]() That helped out quite a bit with highend power, the engine doesn't choke itself at higher RPM's and pulled nearly all the way to redline. Lowend was just a tad better, but still a pretty flat torque curve (according to the butt dyno) up until about 4000 rpm. ![]() ![]() Clean as can be while rallyxing... Don't know how that happens. ![]() So fast forward a few rallyx's, a few photoshoots, and I attend my first pro-rally (LSPR '05, crewed for Matt Johnston, and spectated), and my first winter with my subaru Sunset shot #1 Corner slide Snow meet Exit 2005, enter 2006 And I land in Princeton, IN for a co-op. Middle of no where, but an abundance of gravel roads. That is where I find to practice the flick and to practice a bit more. ![]() ![]() ![]() We like snow and Mowing grass I went to STPR '06 (my 2nd pro-rally), and only spectated. I was quite disappointed with the experience.. I didn't bring away from it as much as I would have liked to. I didnt learn much, and didn't get to know anyone. I decided then, that if I go to any more pro rally events, I would get my hands dirty... either by crewing, co-driving, or try for a media pass. ![]() Up until then I had been running on A/S's, which I had pushed them beyond their limits one too many times. So I pulled the trigger on a set of winterforce's, 205/60/R16s... a little too big, but they got the job done ![]() ![]() Then I started running into problems like this: ![]() ![]() I did some research on springs, and decided I would not be happy with springs alone. I wanted adjustability. I found Ground Control, and decided they were the best option. They were very helpful, although confused when I said I wanted taller springs, that were under 250#. Just a bit different from the norm that they get. They helped me pick the right spring length to go with a set of AGX's that I had decided on. I was so eager to get the parts in, I modeled a few items in Inventor. ![]() I didn't cut the perches, in case I go back to larger coils later on. ![]() I got bored again... ![]() I'm missing a few main components... but dang that took me long enough. Then I hit a deer. April '07. I have the head gaskets, timing belt, water pump, and clutch all replaced. Early May '07 - Bend a rod. Reason to suspect a result of the maintenance performed in April, however dealership blamed it on racing. Then a sales manager said to me before I had my car towed off their property that the failure is likely a result of their work. I'm so mad I didnt have someone with me as a witness to that statement. They quoted me $4200 for a new motor and labor. HA! i'm never going back there again. But I digress... I'll fast forward a few more months, to now, since the RS has seen no action since I had it delivered to its current location. It sat for so long because where I work on my co-op and where I go to school are 3 hours apart. A friend and I pulled the radiator, disconnected all wiring harnesses, removed the pitch mount, and broke loose the transmission bolts. Now all I have to do it pull the motor. I am purchasing a '99 RS motor for $300, and a cross member and PS pump. I'll be updating this, as progress is made on the RS to-do -Rebuild motor -8 or 10 pt FIA spec roll cage -Any used gravel tires I can get my hands on -15" steelies for the gravel tires -Fire extinguishing system -Fixed-back racing seats, any that I can get my hands on -5 pt harnesses -Open face helmet -2 aux driving lights -2 aux fog lights -Terratrip rally computer -Fuel tank aluminum skid plate, poly underbody protection -I-Speed reflash There are tons more odds and ends I will have to buy.. racing suit, shoes, co-driver map light, safety triangles, first aid kit, spill kit, tow hooks, etc. [size = 6]Update 9/12/2007[/size] -Purchased 1999 EJ251. Updated 9/24/07 Finally picked up and delivered the replacement motor to my new residence. The car sits, ready to be worked on. Work will begin this week. I want to pull the motor this week, and then replace the head gaskets/head studs, water pump, and timing belt on the new motor next week. We'll see how that goes. I should mention that two people can man handle an EJ251 longblock. Just for reference. I borrowed my friend's Honda Fit, and picked up my motor along with an extra x-member, PS assembly, WRX sway bars, and some other odds and ends ![]() ![]() Updated 10/3/07 Well I saw these cobwebs, and decided it was time to get to work ![]() Finished up everything in the engine bay that needs to be taken care of in order to pull the motor. I got bored and yanked the alternator, PS reservoir, and AC compressor. All coolant hoses/lines, throttle cable, gas lines, have all been removed. Pulled the starter out as well. All bolts are broken loose on the transmission, so once I secure a hoist, its getting pulled. Someone suggested that I just disassemble it down to the short block, and take it out with the help of a few people. hmm... ![]() ![]() ![]() Updated 10/23/07 The swap is finished. I worked last week on Tuesday to remove the engine. With the help of PAPA, we were able to remove the engine in 1.5 hours. Separating the engine from the transmission took the most time. 2 pry bars, 2 screw drivers, one 8 pound hammer, and one 250lb "deadweight" standing on the transmission finally got the two separated. Worked Thursday/Friday (6pm till 4am) to swap over the clutch/flywheel/pressure plate to the new motor, swap intake manifolds, and install/hookup the motor. With the help of several people from the car club at Purdue (PAPA), we got it done in 10 hours. One of my friends even made a custom clutch alignment tool, since no parts store had one at the time. Which I later purchased one from Autozone for $.01. Booyah!! What an experience. I learned quite a bit and it is good to be back in my Subaru. I drove it around a bit on Friday, 10/19/2007. Put some gas in it. Did it ever feel good. I still can't believe it is finally fixed. Turned the key at 4am, and it fired right up, almost. Removal: ![]() ![]() "What do we do now?" ![]() ![]() Aligning the clutch ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The success shot, at 4am ![]() And video evidence of success!! There is much more to do. Head gaskets are a possibility. Water pump and timing belt will be this winter. Now I have two motors. And I think we discovered what happened to my old motor. I hope to begin tearing into that tomorrow. Updated 10/24/07 So after finishing the swap into my RS, we decided to tear into my old motor to see what was really wrong with it. The dealership that worked on it said that I bent a rod. Well the engine did sound like rod knock, but also sounded like something was tapping inside. Like piston slap. Well when we took the head off, this is what we found ![]() ![]() After examination, general consensus led us to believe it is a drill bit. Left in there by the dealership that replaced my head gaskets, water pump, timing belt, clutch, and a few other things. It took a chunk out of the piston, scored the cylinder wall, and ruined the head. Who the hell leaves a drill bit in an engine? And what were they doing with a drill bit near my engine?! I can't fathom how I was able to drive the car for a little over a week without anything happening. There is no way that thing slipped thru the intake valves at the speed they move at. It had to have been sitting in there somehow. Or maybe it fell thru when I turned off the car, and the intake valve was open enough that it could slip through. Either way. I am taking it to the dealership tomorrow, and asking them who is missing a drill bit. Last edited by I Like It Sideways; 03-09-2010 at 11:52 PM. |
#2 |
DIRTFTMFW
Car: White 2001 2.5RS
Thats quite the write up! I hope the RS gets back in action soon...
\m/ Aaron "Like" us on Facebook! | Follow us on Twitter! | Subscribe on YouTube! ![]() America's / Discount Tire Company|Rally Armor Mudflaps|Soltek Light Systems|Team Illuminata|All Wheels Driven|RalliTEK|GrimmSpeed|Braille Auto Development|Jackson Rally|Millennium Motorsports|Team O'Neil Rally School|Safe Drives |
#3 |
Car: NPB 07 2.5i
looks good man, watch out for the trees
Zebra
Woods - 1 Rex - Gone THE FOZZ
#4 |
Awesome videos,
#5 |
pretty sweet man, good luck with the rest of it.
Not All There Racing #3406 and #577 95 Subaru "The Ugly Panda" 73 Beetle Thanks to our Sponsors: www.teamilluminata.com, B&G Sports, DirtyImpreza.com, Projectsologear, ctsubie.com, EastCoastSwappers, RedBull ! New facebook Page |
#6 | ||
2006/2008 - Western Ohio Region SCCA M4 Champion 2007 - Ohio Valley Region M4 SCCA Champion, 2nd in M4 Western Ohio Region 2008 - Great Lakes Division M4 Champion 2009 - ESC 3rd place M4 ![]() Matthew Noble Marker= - You will not be forgotten. Rally on.
#7 |
DIRTFTMFW
Yeah just take it one step at a time... I find that the project car gets overwhelming if i think about it too much. Its best to focus on one thing and see it through, then keep going!
#8 |
Southwest Regional Moderator
Very nice man! I hope to hear that she is back on the road soon.
Blue '03 Impreza WRX |
#9 |
D.I.R.T. Crew Chief
Authorized Vendor |
Looks good...Definetly get that cage in there.
www.JacksonRally.com |
#10 |
damn these vids make me soo jealous that i dont have a running subaru right now ARGH. sweet vids though
www.grimmspeed.com |
#11 |
I miss your car man. When are we rebuilding the 99 motor?
Oh yeah, and I'm keeping the tires.
2002 Aspen White WRX - gone 1996 Outback Sport - 250,000 miles Never argue with stupid people. They will bring you down to their level and then beat you with experience. |
#12 |
Updated
#13 |
nice man! keep it up!
#14 | |
Thanks!!
Updated Quote:
#15 |
Updated... Getting closer...
